PresentaciónR Tape loading error. 0:1
Si eres un nuevo miembro del Foro, pásate por aquí y preséntate. Nos gustaría conocerte un poco mejor y darte la bienvenida.
AndyP
Ha dado las gracias: 1 vez
Agradecido: 1 vez
#1 R Tape loading error. 0:1
Mensaje por AndyP »
Hello all, and thank you for allowing me in to look at through the forums,
I currently have the following hardware,
48K Issue 2 in + Case, mine since 1982, SVideo modded, recapped, new membrane, ULA replacement.
Interface 1 and Microdrive, mine since 1983. Needs recapped and serviced.
48K+ Issue 4S, recent addition, SVideo modded, recapped, new membrane
48K Issue 4S in original rubber keyed case, recent addition, SVideo modded, recapped, new membrane, ULA replacement.
Interface 1 and Microdrive, recent addition - needs repaired
128K +2, recent addition. Recapped, RGB Mod, Audio Mod, Tape In Mod
128K +2A, recent addition. Recapped, RGB Mod, Audio Mod, Tape In Mod
128K +3, recent addition. Needs serviced
Multiface 1, mine since 1983
Dandanator and Multiply, assembled by myself
DandanatorAMIE Qty 5, built by myself. Must get rid of some.
DivIDE, recent addition.
DivMMC, built by myself. 4 more to build. Will get rid of some once built.
Multiface 3 Enhanced, 5 x PCB and parts ordered. Will get rid of some once built.
Enjoying a 2nd childhood which will be better once I retire.
Agradecido: 839 veces
#2 Re: R Tape loading error. 0:1
Hello AndyP and welcome to the Forum.
It's a pleasure to have you here, as people from your area, Glasgow, UK or further afield, as we find it a bit strange to have users coming in seeing as we don't use your language, although welcome translators... :grin:
We hope to be able to help you with any questions you may have and of course to read you more.
Best regards and here we are... :hola1:
Agradecido: 649 veces
#3 Re: R Tape loading error. 0:1
Welcome Spectrumero friend.
Very nice collection, I only have a Spectrum +3 and I'm very happy with it.
If you want to understand what is said on this site, you can use the translator DeepL.
It's very good and I use it often.
#4 Re: R Tape loading error. 0:1
pintza escribió: 04 May 2022 23:49If you want to understand what is said on this site, you can use the translator DeepL.
El mismo que utilizo yo... :sarcastico1:
Sup3rH4L
#5 Re: R Tape loading error. 0:1
Mensaje por Sup3rH4L »
You have an excellent Spectrum collection. I had the Inves 48+ good memories of that time.
Welcome
#6 Re: R Tape loading error. 0:1
the Toastrack is missing
Coca, Sup3rH4L, Pingui, pintza, Eusebio, Bone, jorsus, AndyP
Usuarios navegando por este Foro: Amazon [Bot] y 3 invitados
