EmuladoresWinUAE 4.4.0 x86 y x64
Neville
Ha agradecido: 7 veces
Agradecido: 144 veces
#1 WinUAE 4.4.0 x86 y x64
Mensaje por Neville »
Ya ha salido la versión 4.4.0 del mejor emulador de Amiga. Estan son las novedades:
New features/improvements:
- 68000 address and bus error (bus errors are not used in Amiga) stack frames are now 100% accurate, including all undefined behavior like partially updated flags or registers. Last missing part that wasn’t fully accurate previously.
- 68010 emulation is now cycle-accurate. Including loop mode.
- 68030 MMU emulation simplified and optimized.
- CPU tester detected rare CPU/FPU bugs fixed.
- Multiple CPU tester detected undocumented CPU and FPU (all models) behavior emulated, mainly edge cases that almost never happen normally. More information in detailed changelogs.
- Debugger assembler and disassembler updates and fixes.
- 1x-8x CPU multipliers are now also supported in prefetch (more compatible) CPU mode.
- Implemented Paula serial port emulation receive break condition detection support.
- “diskchange rdh0:” can be now used to eject drag&drop mounted directory/file/archive harddrive.
- On screen led floppy leds have brighter border if inserted disk is write protected.
- If 2 light pens/guns enabled and if gun 2 moves, enable only gun 2 crosshair. Previously gun 1 move enabled both crosshairs.
- “Default” filter mode now enables aspect ratio correction and scales to window/screen size only when display size is too large or too small.
- Ignore ncap/winpcap dll version because recent ncap versions have smaller version number than old winpcap versions.
GUI Reset button now copies current full GUI config to active config, including options that normally can’t be changed on the fly.
- FPU default is back to 64-bit. Very few programs require 80-bit accuracy, it wasn’t worth the speed loss.
- Black borders are not anymore enabled in autoscale center mode.
- Few custom chipset and CIA emulation updates.
- Added easy to use and transparent printf()-like debug logging method for developers.
Bugs fixed:
- If disk read DMA was started without any selected drive(s), it was always emulated in turbo mode.
- Screen capture to clipboard created blank image if 256 color or less RTG mode and capture before filtering was set.
- When ejecting directory filesystem that points to plain file or archive, not all host file handles were closed properly.
- Switching GUI panels left stale entry in internal array, possibly causing random crash after switching panels many times.
- Config file (*.uae) icon is now correct again.
4.3.0 bugs fixed:
- Some RTG to RTG mode resolution switches didn’t resize windowed mode correctly.
- CD32 pad red button didn’t always work as a normal fire button, depending on how it was configured.
- CD32 ROM delay loop patch was skipped. Broke CD32 CD if CPU speed was too fast.
New emulated hardware:
- Hardital Dotto (clone of ICD AdIDE)
Descargas
WinUAE 4.4.0 x86.7z
WinUAE 4.4.0 x64.7z
Agradecido: 1515 veces
#2 Re: WinUAE 4.4.0 x86 y x64
Muchas gracias por la aportación Neville. :muybien1:
Lo he editado para ajustarlo a nuestro modo de publicación.
314li
#3 Re: WinUAE 4.4.0 x86 y x64
Mensaje por 314li »
Muchas gracias por la información. :loco1:
De vez en cuando, al volver la vista atrás, me asalta la nostalgia... :empatia1:
argibay359
#4 Re: WinUAE 4.4.0 x86 y x64
Mensaje por argibay359 »
Gracias
Santiago-H
Agradecido: 60 veces
#5 Re: WinUAE 4.4.0 x86 y x64
Mensaje por Santiago-H »
Buenas.
Me asalta una duda con las versiones últimas del WINuae. Antaño, había una serie de plugins opcionales para descargar anejo al emulador.
¿Están vigentes dichos plugins? Supongo que las nuevas versiones ya incorporan las mejoras que se hayan considerado como relevantes.
Mirando en la ubicación/ruta donde tengo instalado el Winuae, no veo que exista la subcarpeta plugins.
Y gracias de antemano.
Ha agradecido: 904 veces
Agradecido: 644 veces
#6 Re: WinUAE 4.4.0 x86 y x64
Hola Santiago-H...
Que yo sepa, dentro de mis nulos conocimientos, la carpeta plug-ins la creas o se crea cuando instales algún software que necesite utilizar alguno.
El propio WinUAE no crea esa carpeta porque dicho programa no necesita ningún plug-ing para su funcionamiento.
A esos plug-ins que te refieres pueden ser los plug-in para la PPC CPU Core, Drivers para Sonido, Librerías para el Puerto de Audio, y alguno más, y siguiendo a tu pregunta es si, dichos plug-ins, drivers, librarys, siguen vigentes y los puedes descargar.
Santiago-H
#7 Re: WinUAE 4.4.0 x86 y x64
Siii, exacto Pingui, me refería a esos plugins. Aunque ahora les llaman "extension packages"
He probado el disk drive sound, y en efecto, al descomprimirlo crea la carpeta plugins.
Mi error era de traducción. Pensé que se trataba de un driver mejorado del sonido, y resulta ser la emulación del sonido real de la disquetera amiga cuando lee o escribe en ella.
Pero ahora me asalta una duda respecto del portaudio.libray ¿qué es? . Creo que se trata de un driver/plugin que habilita compatibilidad driver ASIO para programas de musica. Pero creí que lo máximo en audio de amiga era el AHI. Entonces ¿puede un PC conectado a un teclado midi usar programas de audio amiga (Bars & Pipes por ejemplo), con el driver ASIO?.
Última edición por Santiago-H el 14 Nov 2021 19:01, editado 1 vez en total.
#8 Re: WinUAE 4.4.0 x86 y x64
Santiago-H escribió: 04 Nov 2021 11:47Pero ahora me asalta una duda respecto del portaudio.libray ¿qué es?
portaudio.library es una biblioteca de código abierto para la reproducción y grabación de audio. Es una biblioteca multiplataforma, por lo que los programas que la utilizan pueden ejecutarse en muchos sistemas operativos diferentes, incluidos Windows, Mac OS X y Linux.
Santiago-H escribió: 04 Nov 2021 11:47¿Puede un PC conectado a un teclado midi usar programas de audio amiga (barandpipes por ejemplo), con el driver ASIO?
Digo yo que sí, más que nada porque Zoltar3.1 hace música con el Amiga y digo yo que utilizara un PC para ello, no lo sé, la verdad, lo que sí te puedo asegurar es que ASIO lo utilizo para que mi portátil reconozca los equipos que utilizo, Pioneer, cuando monto las fiestas en distintos sitios.
Zoltar3.1
Ha agradecido: 80 veces
Agradecido: 22 veces
#9 Re: WinUAE 4.4.0 x86 y x64
Mensaje por Zoltar3.1 »
Santiago-H escribió: 04 Nov 2021 11:47 Entonces ¿puede un PC conectado a un teclado midi usar programas de audio amiga (barandpipes por ejemplo), con el driver ASIO?.
Perfectamente, además, Instalados los drivers del teclado en el PC actúa como un dispositivo MIDI de entrada en el panel de opciones de WinUAE, y, a partir de ahí, lo tienes disponible para cualquier programa de Amiga que soporte MIDI :tranquilo1:
chupete1970, Goody, Santiago-H, TINGIS53, Bone, pintza, jorsus, Onikyo, Pingui, merlinkv, PuKaSuRf, Zoltar3.1, espinet, Sup3rH4L, DaRaSCo, infodreams, CebollinO, Neville, napsternds, rizosoft, josemrm, droman, Maximus_500plus, centurix, argibay359
